4l60e swap questions
Bacon
Hey guys, so I got a free 4l60 e and decided to swap it in to my 85 k10 4WD. I bought the TCI EZ TCU to control the electronics of the transmission and a 241c TC passenger side drop with VSS sensor hook up. What I would like to know is, am I done? Can I plug and play now?! I'm hoping the the output shaft speed connection from the TCU will connect to the 241's vehicle speed output and function as normal. Any insight would be great
yevgenievich
Viktor
sad
very sad
less sad
You would need to change to electronic spedo cluster or run a conversion box. You would need to mount your throttle position sensor as well
Bacon
I forgot to mention that I have the TPS. I don't care too much about speedo because I have a gps speedo on my rino
Bacon
Does it matter how I orientate the 2 wire hook-up for the output shaft speed that connects to the VSS sensor? Will the 2 male blades from the sensor send the same signal if I rotate the connector? I don't know how to words this better unfortunately.
yevgenievich
Viktor
sad
very sad
less sad
it should not matter, and your tcu should be programmable. You would just use your gps spedo to calibrate the tci tcu. Double check the output shaft on the transfer case to make sure same as existing.(241c was used with 700r and th400/4l80e)
Bacon
The input shaft splines were 27 for the TC and that is same as 700r4.. So I'm assuming out put should be 27 right? I'm still a newbie so I hope that's right. Also I read something about AC sine wave created by this 241 c sensor. Will that signal work in this TCU?
yevgenievich
Viktor
sad
very sad
less sad
I would assume tci tcu would be able to work with it. If it fails, then can install a factory drac box in between.
Steveo75
