454 eating starters
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
3 new proform high torque mini starters in 2 months? Crappy design or something else. I do have long tube headers and its close to starter i have a heat shield wrapped around it. It seems to be strong at first then after time they slow down.
Mostly stock old motor.
72chevy2door
Florida
Jeff
1500 Sierra Classic suburban
My fathers suburban ate starters all the time. Never knew why. It eventually started destroying the flex plate. The timing was good. You bumped the key and it would fire right up but a factory replacement starter wouldn't last but a couple months.
yevgenievich
Viktor
sad
very sad
less sad
Double check the clearence and check if need to use to use a shim between the block and the starter. Some big blocks also have additional bracket to support the starter.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
It has two shims in it now looks sounds good starting some times then theres just random times where it bogs the starter like its a high compression motor idk
I personally don't like mini starters. All of them I've dealt with have failed when still nearly new, and half of them have the motor housing rotated closer to the header than a stock starter.
I'd go with a '95-newer starter. They are smaller than the old style, but seem to have more power. But they do require shorter bolts.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Ya im taking it back and getting regular one. Its a pos bendix sticks on running and have to disconnect the battery cables
highdesertrange
kalifornia
mike
k30
my 454 was eating starters too. what I did was install a starter for a 1969 chevelle 396 4spd. they have a cast iron nose cone. I went from a starter every 6 months to this one that's been in for 4 years. highdesertranger
HectorGarcia415
