77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
Working through some issues still, besides the tune. Some solved, some still lingering.
4. Temp gauge issue. There are two temp sensors: one in one of the cylinder heads with one wire and one in the intake manifold by the thermostat with two wires. The two wire one controls the ECM, and fortunately that one is working fine. My data log sessions show a very consistent 175-185 deg f after it's warm. But the one in the cylinder head controls the temp gauge on the dash and it is wonky. It'll be pegged hot at one minute and show 190 the next. And I don't see any consistency. It's a new temp sensor so I'm thinking I might have bought an incorrect one. I believe I have an OEM sensor that I can put in there so I'm going to try that and see what happens, but if anyone has any ideas, let me know.
More bugs to work on besides these, but that's enough for now!
On my truck I was getting temperature fluctuations while on the highway with the coolant temp sensor in the head (which goes to my VDO coolant gauge). I have another coolant temp sensor in the manifold for my fuel injection and that one was pretty steady. In my case it was called out in my GM crate engine manual:
"Any small block engine, regardless of year, that uses Vortec heads, will require an external coolant bypass line from the intake
manifold to the 5/8" hose nipple on the water pump (passenger’s side). Suggested routing is from the 3/8 NPSF boss on intake
manifold to the water pump."
Something about coolant/water will boil in the head then force its way out somewhere else then cooler coolant then comes rushing back in. In my case if I remember right this would happen every 10-20 seconds while going down the highway. I added a coolant bypass and the issue went away. Others say instead of a coolant bypass just drill 1-3 holes in your thermostat to allow coolant to bypass.
