38 yr old Ziebart
woodsrider250
Fredneck, MD
350-Qjet
Quick opinion on cancer repair, and trying to do a more 'original' light restoration of my 74. It's in immaculate condition considering it didn't come from AZ or something, but some rust is starting. It was Ziebart'd in '74 when new along with a slew of other dealer options. The ziebart saved the truck, but is now starting to destroy it in spots. If it cracks, it ends up making a barrier that holds moisture in.
So I'm not sure which direction to go. Anyone know the best way or how bad it is to get this **** off? I could put it on a lift, and start going to town with a sand blaster. I could grind away as lightly cancerous spots, repair, then re-undercoat the whole thing, but down the road the truck could be worth less covered in undercoating. What should the factory finish be underneath? Flat black? If I did the blasting I could repaint underneath with POR15/Rustoleum. Just looking for some opinions before I :superhack:
Can you post pics of the problem areas?
Try a needle scaling gun. They kick ass. Google or YouTube it and look at the videos.
Posted From Hell
woodsrider250
Fredneck, MD
350-Qjet
Cool, thanks.....will get some pics.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Im a true believer in Ziebart! My '96 F-350 had it done from the factory and It has basically ZERO rust even after 200,000 miles in MICHIGAN! That's impressive!
Would a good wash in Dawn dish soap do it? Itll take wax, grease, etc off on a normal car but not so sure on a Ziebart coated one. Just a thought!
superbee70
wny
tom
Best way to get off most undercoating is to heat it up and scrape it off. It's alot of fun. I did all of my superbee this way, propane torch in one hand and scraper in the other. Some guys have said they had success with a steam genie/pressure washer combo.
But your right, once it cracks it will hold moisture and you'll get surface rust underneath the undercoat.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Yup, and this will also help track down any unknown fuel leaks too! LoL!
superbee70
wny
tom
Yep, good idea to have fuel lines removed, rugs out, etc. I was doing a complete rebuild and basically working with a shell.
JohnnyOwens
Albany
Johnny
c30
Quick opinion on cancer repair, and trying to do a more 'original' led lights restoration of my 74. It's in immaculate condition considering it didn't come from AZ or something, but some rust is starting. It was Ziebart'd in '74 when new along with a slew of other dealer options. The ziebart saved the truck, but is now starting to destroy it in spots. If it cracks, it ends up making a barrier that holds moisture in.
You have not shared any pics till now.. I will really help me if you have some pics to share.. Thanks in advance..
Pugs Speed Shop
