- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
OK, now we're getting somewhere. So it's certianly NO 700r4 and is a Th350. So this leak, was it the modulator itself leaking at a seam, or was the fluid in the vac hose being sucked into the engine, or was it the O ring where the modulator goes into the case?Sorry if I was being confusing. It's the 350 Transmission it has the vacuum module on the side of the transmission it was leaking transmission fluid so I had it replaced when I pull the vacuum hose off of the modules it leak transmission fluid that's why I replaced it
