305 to 350
T Anderson
Nebraska
Terry
Ive got a stock 305 in my k10. I'm picking up a built 350. Its got about 400 HP and not sure on torque. Its never been on the Dino. I know my rear end a and tranission will need beefed up. Will I need stronger motor mounts? Will I need anything else for the swap. Motor is already broke in. Any help will be appreciated.
firebane
Calgary, AB
Curtis
LOL. The difference between a 305 and 350 isn't that much. Just bolt in and go! If something breaks then upgrade.
350runner
tx
Ceasar
nothing needed but better tires:)
T Anderson
Nebraska
Terry
I had a few guys tell me I needed a bunch of stuff for the swap. I called them out. Just wanted to double check.
CSFJ
It's been a dozen years since I did this swap. The mounts are the same. All the big pieces are the same the things that end up being different are a bunch of minor pain in the ass little details. If you're using the factory exhaust manifolds, the passenger side one has a different bolt spacing on the rear most cylinder. Seems like there were a few other things a was swearing at, but I can't remember anymore. Like I said, minor bs stuff. If you've got some extra parts from different donor vehicles you should be fine.
T Anderson
Nebraska
Terry
I'm going to be using long tube headers. Only thing I'll have to change over is my power steering pump. Hopefully it won't be too bad. I've changed em before though.
MadOgre
NA
NA
NA
NA
NA
Why ? Just pull it off the motor and push it to the side then reinstall on the new motor. Then change pulleys if need be or run the 305 pulleys on the 350 and everything will be good still.
T Anderson
Nebraska
Terry
He had the motor in a mustang. I don't want to run manifolds on it from my 305.
MadOgre
NA
NA
NA
NA
NA
I hope you mean he retro fit a GM small block into a mustang and not that you are planning on putting a 351 Windsor into your GM truck ???
The power steering pump has nothing to do with exhaust manifolds. It bolts onto the front of the block with one mounting spot on the one forward most exhaust manifold bolt which is the same from 305 to 350 unless you run headers in which case you just need a long bolt and a spacer to make it work.
firebane
Calgary, AB
Curtis
My power steering pump brackets bolt up to my exhaust manifold :shrug:
MadOgre
NA
NA
NA
NA
NA
Only one bolt. and if you run headers you just use a long bolt with a spacer to position the pump bracket correctly.
Absolutely no need to change power steering pumps unless its shot.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
.... If you're using the factory exhaust manifolds, the passenger side one has a different bolt spacing on the rear most cylinder.......
That's odd. I took out a 283 and replaced it with a 350 and the factory manifolds bolted right up. Those were ramhorn manifolds so you don't need the spreader like you do with the stock manifolds on these trucks, perhaps that is what happened, the manifold on that side closed on itself and needed to be spread out to match the holes on the head. Without the spreader tool to keep the manifolds from closing up, the manifolds are a bear to put back on. They only close up a little amount but it's enough to make the holes not match the head.
CSFJ
CSFJ
Never played with a 283, but the 305 manifolds have the rear most bolt farther back than on a 350. That's why the exhaust manifold gaskets on the block have the double bolt hole on one of them. So they can be used with a 305 or 350.
CSFJ
I can see what you mean about the rams horn style, but this is entirely different.
jrocK
