Pender1
- Nov 12, 2014
- SC
- Brian
- 1986|2014
- K5|1500
- 5.3L|5.3L
I pulled the 305 out of my '84 K10 and stuck it and the SM465 attached to it into my '86 K5. Other than burning some oil and not having a ton of HP, it ran great in the K10, but since I've put it in the K5 it's not doing so great.
Under accel it backfires bad out of the carb. I've got ~17" of vacuum and can't find a leak. I've tried with and without a fuel regulator in line. I've tried anywhere from 8-18 degrees of initial timing (without the vacuum advance hooked up). I've tried running it with and without the vacuum advance connected. It all does the same. I've adjusted my carb as best as I can using a gauge (Edlebrock 4bbl). I also had the Holley 4bbl that was originally on it and it did the same thing.
I've seen a couple of posts that say it may be a wiped cam, but this engine ran great before, so I don't see why it would have all of the sudden killed a cam.
Any suggestions? Ideas?
