3/4 ton vs 1ton
fowjacob
Lubbock,TX
c3500
383 Stroker
Can someone help me out with figuring out if my truck is a 3/4 ton or a 1 ton.
1983 gmc 3+3 long box with 14b ff rear end.
Is there and easy way to tell? Codes, vin?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
C2500 means 3/4 ton, if it were 1 ton it would be C3500 and more than likely have dual rear wheels. Also the leaf spring perch spacing on the rear axle is a good indicator. If you have 42.5" from leaf spring center pin to center pin it is a 3/4 ton. 40.5" would be 1-ton.
fowjacob
Lubbock,TX
c3500
383 Stroker
I understand the 2500 thing but my truck doesn't have any badges ill measure the springs tonight but more then Likely it's a 3/4 with the heavy duty rpo code thing that hotrod was talking about on his (ff vs sf) sticky
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
3+3 crew cab i think the crews all used the same 1 ton frame so spring perches would be the 1 ton spring perches narrow.
2 wheel drive or 4x4?
look at the gvwr sticker in the door frame 4x4 1 ton is 10,000 pounds 2 wheel 1 ton is 9,000 pounds 3/4 ton would be less.
those gvwr are for a single cab square 1 ton not sure if a crew is different or not
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Here is the VIN decoder from LMC catalog.
Sixth digit will tell you which series. 1500, 2500, 3500
Also C2500 with has a C6P option code (look on the glovebox door options list) that added bigger brakes and stuff.
Yep, his will be set up like a 1 ton even if it is a 3/4 ton. Pretty much it is a 1 ton even if it's a 3/4 ton. Spring pack might be different, and if 3/4 ton 4x4, still got the 10 bolt front axle instead of Dana 60.
fowjacob
Lubbock,TX
c3500
383 Stroker
Yeah Vin said its a 3/4
So all the rear end stuff is the same at as 1 ton?
What about the frame? 3/4 or 1 ton
If it's a crew cab or 3+3, it's a 1 ton frame. ALL CREW CAB squares are 1 ton frame regardless if it's 3/4 or 1 ton.
crazy4offroad
Curt
K-10
350/SM465/NP205
The axles are very similar in stoutness between 3/4 ton and SRW 1-ton but best way to tell is measure the leaf spring perches like I said earlier.
Yeah, I'd stll measure the perch distance, cuz I think the only difference and reason the 1 ton and 3/4 ton spring distance is different is due to the spring hangers. If you still have 3/4 ton spring hangers on the 1 ton frame, then the distance should be the same as any other 1/2 or 3/4 ton. If it's got 1 ton spring hangers then the distance will be more narrow. It would ge good to know too since you happen to have a 3/4 ton Crew Cab.. Lucky Fugger !!!
In fact, why don't you take us some pics of your rear axle and springs in that rig? Lets see the spring hangers, perches, shock mount brackets etc. That will be another thing that is different, is the shock hangers. Shock hangers are opposite of 3/4 and 1/2 ton on the 1 ton spring trucks. It would be interesting to know this info for certain. I almost hope it's actually all the same as 3/4 and 1/3 ton specs and measurement, but I have a feeling it's going to be just like a 1 ton.
fowjacob
Lubbock,TX
c3500
383 Stroker
Back spring hanger
Front spring hanger
Axle and kinda the shocks
Sorry at school thats all the pics I had on my phone I can get some more when I get home. She's a 2wd also for who ever asked
fowjacob
Lubbock,TX
c3500
383 Stroker
When you say measure perch distance do you me the perch it self (thing that the spring sits on, on the axle right?) or from perch to perch? Sorry kinda confused there.
Ill agree with ya on being a lucky fugger :)!!
Looks like a 1 ton set up to me. I know the shocks are 1 ton set up. Spring perches look close to the frame, which will make the spring perch distance more narrow.
This is a 3/4 ton set up. Notice the difference in spring hanger distance to the frame, and notice the direction of the shocks.
attachment.php
attachment.php
nr9016643
