3+3 badge?
Dougnsalem
I hope they are still there. It's quite possible that the body sheet metal rusted out more, and they fell off...
Big Chip
Michigan
Kevin
C35
Pics to prove it, or you added them on after you got it home. Lol. Smh. Limo lights.... (I'm done. For now....)
I'll run out and get a pic of mine.
Dougnsalem
LMAO. Ok, ok, you win. I don't know if it matters but my truck was originally silver with a burgundy/maroon insert. The emblems look OE, and haven't been painted. 1979 1 ton Crew Cab Dually.
You must have forgot about my delightful pinstriping, as I give you crap about your lights. It's almost all gone now.
Edit: hold up here. That light looks photoshopped..... Lol
Big Chip
Michigan
Kevin
C35
LMAO. Ok, ok, you win. I don't know if it matters but mine was originally silver with a burgundy/maroon insert. The emblems look OE, and haven't been painted. 1979 1 ton Crew Cab Dually.
The rust probably started where the limo lights were screwed on.
I wish mine still had the 3+3 badges. They were removed along with the rest of the side trim.
78C10BigTen
pennsylvannia
C10 BIG TEN
From afar the rust spots look like muzzel loader ball dents lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Are those tie down hooks going down the box factory?
Agreed. I’m glad mine still has them and the SLE badges :)
Now....to get pointers on how one actually polishes these badges up cuz I’m still not certain how one goes about that
Big Chip
Michigan
Kevin
C35
Dremel has to make something I would think. Maybe a regular polishing pad on a grinder motor?
I may do some researching into dremel extensions then. I’ve only used my dremel to cut plastic or metal and the little sanding extensions so I’ll have to see if they have little polishing pads lol
I always use #0000 steel wool and do it by hand, then wipe it down with a soft wash/polishing rag.
They do make little buffer wheels for the Dremel.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Dremel does make polishing wheels. I had one for mine but can't find it. Lol
12turnda
