2wd conversion to 4wd
vortec997
tennessee
charlie
If i buy a square body crew cab such as a dually is the frame the same as a 4wd. I have found it very difficult to find a square body crew cab unless its a 2wd dually any info would be appreciated.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
EvilGenius
Metro Detroit
Darien
Unfortunately no. The front suspension components would need to be removed and some cross-members need to change among other things. It is much easier to do a frame swap. There is a guy on here currently in the process of converting a 2wd to a 4x4 by modifying the original frame. It's really in depth and well documented. Build thread of that can be found here.
Welcome to the site as well!
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I have the same issue, or just really clean 1 tons are always 2wd. Ive looked at DIY4X's I think they call it the A-bomb im not sure. But its the easiest way in my opinion to do the swap, I believe it serves as a winch mount and you can build a custom bumper off of it, as well as it strengthens the front of the frame. It takes the place of the factory core support body mounts, and it has multiple mounting points for the front spring hanger. Its pretty slick
rpcraft
Robert
LS 6.0 364 CID
Somewhat of a sideways solution, but you perhaps could graft the front of a 4wd k10/k20 frame somewhere along where the front part of the crew cab frame meets up under the cab section. For the most part everything on the front part of a one ton 4wd frame is going to be the same as a 1/2 and 3/4 ton frame, the only thing that changes are the front axle's. You could just cut and chop the frame rails, then plate and box them for strength. Essentially the same process as what they do for converting from long bed to short bed, you just have to find the common spot to cut and weld. I figure it would be easier than trying to adapt all the 4wd hangers and parts to a 2wd frame.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Maybe by DIY has a B52 kit for 2x2s... so you don;t have to mod the 4x4 bracket. More guys hanging B52s on 2x trucks these days.
I might go this route myself, running out of 4x frames around here. So much rust.
I would spring for ORD's springs. They have multi thin leaf packs for 52" conversions. They have the correct spring rates... better than a used rear 52".
Craig 85
Nashville, TN
454/TH-400/NP205
In addition to all the modification you do on the front section of the frame, the rear spring hangers on K series truck are about 2" longer. So those will need to be changed too.
climb-101
montana
seth
c2 crew cab
6.0 LS
i’m in the process of doing the swap. my build thread is linked already in one of the first posts. if you have any questions feel free to send me a message. one thing to watch out for is that the 3/4 crew cabs wer on a 1 ton frame so make sure you order 1 ton parts ( not sure if this is all year but at least the early ones are that way)
also the are floors are different between the 4wd and 2wd. i’m running the 2wd cab but i dropped the motor/trans down instead of adding a body lift
NastyBuzzard
South Carolina
Justin
V1500
350TBI
We actually sell a true conversion kit for 1 tons or crew cabs. We have install videos on youtube and have a few options for kits. Our front setup actually puts the leaf springs parallel to the ground so pinion angle stays correct. Our rear hangers lift the rear to match the factory k30 height. We also use as many original bolt holes as possible so you wont have to butcher the frame.
LHredneck
Gerald
I’m doing a 2wd to 4wd swap right now except a k20 to a short bed c10
Everything from the back of the gas tanks is the same if the rear springs are the same length
I just went slow and took lots of measurements and double checked the measurements
Hardest thing is getting factory rivets out
NastyBuzzard
South Carolina
Justin
V1500
350TBI
Yeah those rivets are pretty time consuming unless you have a real good air hammer along with a nice air compressor. Ive removed so many with a cut off wheel, drill and a punch.
Charkmapman
