205 vss conversion?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i am looking at putting a vss in my 205
i have seen a few poeple have done it useing a reluctor ring and speed sensor from a 241.
the reluctor ring needs to be thinned out to match the width of the speedo gear. and the sensor needs a flat spot milled out and then drilled and tapped.
any ideas or thoughts
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
You can get one that screws in place of the speedo cable, then the cable screws into the vss. You have the CB coax type speedo cable, right? And which truck is this for?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ya i know about the inline vss
but i think one mounted in the tail housing would be better
its for my crew with a vortec 383 4l80 205
Jims86
Patterson,Ca
5.7 TBI
Ahhhh...I see. Thought you were talkin TBI.
There is an inline that is a 4 pole if you cant find the reluctor ring type for your 205.
Do you just need the VSS for the trans control? The inline sensors work fine and let you keep your cable speedo cluster. Or are you going with the electric speedo?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i am not sure what all it is needed for tranny control speedo and so on.
i just got a nice dash cluster out of a 91 suburban so i will have a electric speedo if i pull this vss swap off.
i would like not to use an aftermarket inline vss. i want to try and use off the shelf gm parts as much as possable. that way i can go to almost any parts house in the country and get replacement parts should i ever break down away from home.
and it will be as close to the correct vss as i can get for my set up. 40 pulse per driveline rev
it seems like a pretty simple install for the vss and i know its possable just need to get it together.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
Jims86
Patterson,Ca
5.7 TBI
a stock vss for a 90-92 TPI Camaro might work, it is a 4000ppm sensor, uses a gear instead of a reluctor ring, and is held in by the same 10mm bolt and hold down clip.
Swims350
Logan WV
none
why not use a 241 case? the 88-91's had the ps drop and vss.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I must correct you friend.
1990-91 Suburban/Blazer/Jimmy used the 241C with VSS.
1991 V3500s used the 205 with VSS.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i have already had my 400 205 adapter machined to fit the 4l80 got the call today its done. so i have the 205 ready to go on the 4l80
and there is no way i would use a 241 over a 205 unless the 241 is all i had
1 ton crew cab with 35'' tires would be hard on a 241
thanks for the camaro info but i want to try to run the correct vss not just make something work. thats my reason for wanting to stay with the 205 vss install. it will ad a hurtle in my build but it will simplify alot later on having the correct 40 pulse vss for the drivetrain i'm running.
Swims350
Logan WV
none
no prob. retro.
as for a 241 on 35's see the gmt400 guys do it all the time even bigger then 35's.
I don't blame you for using it when the thing is already machined and you have a 205.
are the in line deals pretty expensive? I considered using one on my gmt400 if I can do SAS due to it having electric in dash speedo and maybe running a reg. 208 or 205 t-case with ps drop.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
they are 70 to 120 bucks depending on witch one you get
look up jags that run they have a couple styles
Swims350
Logan WV
none
awesome thanks for the info.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
got the reluctor ring and sensor today
i had a 89 s10 t case sitting in the back yard so i pulled it apart to see if the parts would work looks like they will
jcuriel512
