77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
So I've been trying to find a replacement rear driveshaft for my truck. Right now I have a 1350 u joint at the differential but only have a 1310 u joint at the back of the transfer case.
One driveline shop said on a 3/4 ton both u joints should be the same size.
Did someone maybe swap out the 203 with a 1/2 ton before I owned it? And the 1/2 ton has a smaller u joint at the yoke?
Or they said replace the yoke out of the 203 with a flange where a 1350 CV could bolt up. How easy is that to do? Can that be done with the transfer case in the truck, or does the whole thing need to be dropped?
