1999 Saturn sl2
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
This was the window switch I bought...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So I got the window switch and nada....does nothing... To make sure they didnt send a defective unit, I put stock in which worked in 3/4 window switches.... Still nothing.... So now im playing the fuse game....but after all the mini fuses have gone on to fuse box style....
This is 1/2 plugs that goes into the switch....how I hotwired the window closed....
2/2 switch plug
This is schematic for fuse panel in passenger fender well
Real life pic...
This is the fuse box under the hood...
It's been getting Sacramento hot again so only willing to work a few select hours before sundown.... Still working it... So now turn signals work... Remaining real issues are clockspring/abs light, and horn buttons, and window switch...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Expensive little bugger.... But dont know if used will be too much a hassle to be worth it....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Real happy.... Found the issue.....
It was the underhood fuse panel first upper right corner 30 amp
Blown....
Only mechanical issue left is after fixing the blinkers switch behind steering wheel I musta somehow messed up the clockspring (even though I tried not to by taping it still) causing the abs light to come on...
I avoided this job on mini me, and may have to research it more, but everything else is going good...
dbarham78
