1990 Suburban ECM-1 fuse blows, again & again :-(
CWGRL
SOCAL
JW
V2500
You mean that stuff don't work or it's unhooked?
I unplugged everything... LOL
Thanks for all your help!
Another question, is there a trailer brake controller wired into the vehicle?
CWGRL
SOCAL
JW
V2500
Question.... is the main source of power to the fuse panel come from the harness in the engine compartment? :suicide:
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
There should be two, one from alternator, and one from the starter.
Here is a pic of my mystery fuse, it has a 3 amp fuse in it, Retro took a high heel to my nuts and said it's for the starter circuit in my build thread.
:nutkick: So right there is something strange, yours is 30 amp fuse and mine is 3 amp, maybe a clue? I don't recall seeing that in my '89 harness but after I finish up my breakfast here I will go check it out.
So then we just need to figure out what both your Burbs have in common to figure it out that most other squares don't have. How about Power Mirrors?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
sorrybto beat adead horse, but did you unplug both injectors too?
CWGRL
SOCAL
JW
V2500
sorry to beat a dead horse, but did you unplug both injectors too?
I was able to get the truck in the backyard, paid tow co. $80 :Boo:
as of this moment here is what is unplugged.
Injectors, Map, IAC, EGR solenoid, ESC, ECM, O2, Tranny, Fuel pump, relays, oil pressure sending unit, TPS, Coolant temp gauge, no radio, no dome lights, dash gauges completely unplugged, alternator, kickdown switch, and any pink/blk plug under dash.
I also removed distributor, and coil. check harness against firewall, all looks good.
Still blows fuse! Maybe, fuse panel?
I borrowed a Power Probe from a friend but at this point, I have no idea where to start probing! LMAO
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
At this point, a chafed wire that's dead shorting on some metal is the most likely culprit. Check where the ECM wiring passes through the firewall at the rubber grommet.
That fuse holder is supposed to have a 3 amp, not a 30 amp so something there is wonky as well.
Wonky??? :shrug:
MrMarty51
Eastern Montana
Martin
There is a whole mess of wires, I`ma thinking, that is run through brackets behind the heads, theys a real sunnygun to get to, maby something along there ???
Fuel pump wire, all alng the frame rail ???
fuel pump itself ???
Jims86
Patterson,Ca
5.7 TBI
Check behind the glove box under th ecm....sometimes the harness comes loose, and lays on the temp cotrol cable, and wears through the harness.
satansdad
