1987 trouble/problems
m1000snopro
Palisade, Co
Joshua
I Have a 1987 chevy half ton. the other day I was driving and it shut down on me. got it towed home. I thought I may have ran out of gas so filled up both tanks with new gas. all it was doing was just cranking no start. i went a day later and switched tanks and now it will idle really rough for about 5 seconds and shut down. i have changed the fuel filter, took out injectors and cleaned screen. im running out of ideas any help would be appreciated
note: motor is new has about 15k on it, including everything from top to bottom. have a high pressure fuel pump in drivers side and regular pump in passenger side.
Fuel pressure test, do you have spark?
87ScottW
