- May 18, 2020
- Washington
- Todd
- K20
Seems there is some real variability in the placement of these with respect to the lines on the front fender. And some just look totally "off".
Even looking at the factory brochure, there was a big difference between 2 different trucks as far as how it lines up on the front 1/3 or so of the fender.
Looking for opinions here. The way the new stripes are molded ( I have them, pic is from the website), it appears that the stripe "follows" the "valley" or bottom of the curve in the upper part of the fender, with a very pronounced curve.
"Most" trucks, the ones that don't just look completely wrong, seem to not curve as much, factory brochure included (but the 2 pics in there are probably an inch different, lol)
First pic is how I have it laid out currently. Follows a straight line forward from the door for over half the length of the fender, parallel to the upper body line, then starts following the line of the low part of the curve, which also drops with the top of fender line. Near the front, that curve warps down to meet the body line and stripe follows that and the drop in the top of fender, basically equally.
Second pic is how the truck looked previous, each side was different in height refernece but similar in the curve down at the front. Not near as pronounced as I hav eit and not following the line of that valley in the fender.
Third pic is the stripes as molded, the ones I have are the same and they seem much closer to what I've laid out with a more pronounced dip at the front part of the fender.
Opinions?
This thing is getting the rest of the paint on it this weekend and the tape line needs to be within less than 3/8" of where the stripe is going, to cover it, so no major changes after paint.
Opinions?
