1986 TBI engine upgrade questions
Dr Evil
Tennessee
Russ
I have the opportunity to pick up an 86 G10 4wd long bed. It needs a couple things, nothing I can't handle after what I just went through on my 74 build.
I want something suitable for daily driver use but would likely only be used for weekends hauling the boat or normal truck duties.
The truck currently has a 305/700 combo. I like the overdrive.
I like the TBI system
I dislike the 305.
How hard is it to upgrade the TBI to support a mild 350 build?
I'd build another engine very similar to what I built for my 74.
350 roller motor
.030 over
Mild cam... Probably in the 204int 212ex mid .450 lift range on a 116
Possibly set of small chamber 305ho heads.
Headers.
This combo works really well for good driveability in a truck. Combined with over drive it would make a very nice driver.
Is this doable while retaining the TBI?
I assume I will need to swap injectors and proms. Anything else?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Prom, injectors, ecm
I have a recommendation for a prom chip burner guy as well.
Vbb199
Salisbury NC
Vince
Maybe the actual tbi itself? Idk what the cfm is for a 305 tbi.
The 350 tbi is advertised at 500cfm.
Dr Evil
Tennessee
Russ
So it's not a huge under taking? Those parts are pretty easy to find. Even better if a custom prom can be easily burned.
Is there a difference between the ECMs though? I figured it was a prom issue, not necessarily the ECM.
Any issues to worry about with a different ECM running the other functions like TC lock up?
Vbb199
Salisbury NC
Vince
Prom does fueling, afr, timing curves, and **** with TPS and some other variables.
Thinking on it, youre correct.
That prom is whats needed.
You also need a
350 specific knock sensor
350 ESC module
Vbb199
Salisbury NC
Vince
From what ive understood , the tbi system only does a max of 400hp.
My motor makes 330hp, 385 ft lbs (engine alone, no mods)
On my 89 tbi ive got a performance prom, EGR delete and blockoff, aftermarket 30k coil and ignition box, nee HP distributor, and regapped plugs appropriately for the C/r.
After all that, the poor flow of the 500cfm unit has been exposed. In conjunction with vortec heads. Its sucking for air at WOT
Even in that state, for a 89 r1500 burb.... it fuggin MOVES with a 3.42 and 31" tire (undergeared)
Ive machined myself a 46mm bore tbi to go on my truck, and will also need another prom for it.
Just a thought for you if you are heading the route of a high performance motor and using tbi.
Dr Evil
Tennessee
Russ
No high performance goals here but improved driveability and everyday power would be great.
300hp 350trq would be fine.
1998_K1500_Sub
