1982 idiot light to gauge upgrade.
Galane
Idaho
Gregg
Sierra 3500
Plug and play or do I need to move some wires in the wiring harness plug?
You need to move some wires.
But rather than disturbing the harness connector (and moving the pins around), it is often quicker - and way easier - to switch the inputs by cutting and re-aligning the leads that feed the connector.
Pin outs for an 82 with base cluster:
Pin outs for an 82 with gauges (with & without tach):
Apologies for the quality of the dwgs - but if you look at the lines going into the connectors you can read the color/number designations.
70meyers
