1982 GMC B6000 axle?
nastiliusprime
new orleans
nastilius
B6000 B series, Bus Chassis
8.2L V8 Diesel
Greetings,
I am new on here as this is not my bus, I am just trying to help a friend find the piece they need.
Attached are some images of problem area. The only pieces I am finding readily available for this model are the wheel bearing, and driveshaft support....I am not even quite sure what to call this threaded end of what I would usually call an axle/cv to hub connector.
Anyways hopefully someone far more knowledgeable than me on the model can help with recommendations on where to find pieces, or at very least the proper name for the piece in question so i can post in classifieds.
Any other insight is also welcome.
Thanks in advance.
Peace
That is called a spindle. In a 4wd application that spindle would be hollow and would have the axle passing through it. In a 2wd application like yours it is just a solid bar.
nastiliusprime
new orleans
nastilius
8.2L V8 Diesel
thank you, this I have only worked on FWD drivetrains prior.
Any suggestions on parts sites? Or are the classifieds here best bet
Thanks again
Thanks again
Well, its not really a square body... so I wouldn't expect anyone here to have much knowledge or parts for it. I would suggest a heavy truck forum or a bus forum. The only site that I know of that is for medium duty trucks is stovebolt.com... but that is for pre-73 GM trucks.
nastiliusprime
new orleans
nastilius
8.2L V8 Diesel
copy.
thanks again
If you figure out what model the front axle is, you will have a much easier time finding a good used spindle. I'll bet the same parts were used in a lot of the squarebody medium duty trucks, and there's people that part those out.
80BrownK10
Greenwood, SC
Nate
Greetings,
Thanks in advance.
Peace
Why is it all scarred up from a grinder? Looks like someone cut a seized bearing off but then tried to caveman smooth it up?:33:
80BrownK10
Greenwood, SC
Nate
Bus Grease Monkey has a forum. He is also on YouTube. I would check out his forum. It's a buss forum, I'm sure someone there has knowledge as well as a parts source.
PapaBear8486
