1980 k10 dual shocks to single
Raider L
Shreveport, LA
William
@lifeofbriank10,
In the last pic it looks like the upper rear bracket has been whacked on that one side. Were you still planning on using double shocks? If so and you plan on staightening that bracket out I would inspect it afterwards very very carefully for cracks on that one ear. Our old trucks don't like to have metal beaten back and forth without breaking off suddenly.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
One thing to remember, is, on trucks with original quad front shocks, the valving was cut in 1/2 on the shocks used. 2 - 1/2 valved (probably not the right term) shocks equal the same stiffness as the regular shocks used on the normal dual shock setup. “Front quad shocks” is how it is listed on my SPID
I’ve been searching for a set for the front of my truck, since I put the lift on 20 years ago, and while some manufactures say they are to run as “pairs” they are entirely too stiff to run together.
Washington
The shorter one looks a little compressed in this position as well. Am I wrong in thinking this looks as it should?
These are the shocks I ordered. Sorry for all the newb questions.
Shock looks to be an inch or 2 too long. But then again your springs look pretty sacked so could be the right application. That pic makes it look like you need to compress it another inch or so just to get the bolt to make up.
It’ll probably be fine but you need to do the measuring. Hard to measure your truck from the internet….
89GMCJimmy
ivan
Everyone has their own opinion for me the auxiliary position more vertical up and down makes my truck handle much better but I do have the 5100s as far as the bottom bolt. I would run it through both holes with a long bolt.
SquareRoot
Newb question here. Why run two shocks and was it really an OEM thing? Was it an option or across the board.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Option. what I was told by a dealer back in the 80s was that it took longer to heat up the oil in 4 shocks if using off road than it did 2.
SquareRoot
That answers two of the questions. Thanks
SquareRoot
Something left out?
The "why run two shocks". What was the logic back then? If it was a good idea, it would still be around. I'm just curious because these trucks weren't exactly made to run the Baja 500.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Because ADS hadn’t built these yet…
nvrenuf
Mobile, Al.
As previously stated by @vr1967, the idea was to add shocks to compensate for old technology that caused shocks to get stiff / somewhat rigid when cycled fast and hard. You don’t see dual shocks now because technology has advanced to the point that 1 can do the job of 2 now.
That said, I always loved the look of the quad shock option.
Minnesota
1980/1984 Frankenstein
K10 Silverado
Starting on the rear and the bottom has way to much wiggle room as you can see. Am I supposed to put the washers on the inside?
nvrenuf
Mobile, Al.
Yeah, you need to fill the gap. stock shocks may have a tad bit of the bolt sleeve sticking out on each side to take up that slack.
If you don't want to stack washers DIY4X.com sells "Heavy Washers" that are 1/4" thick that might look cleaner.
630erik1
