1979 Chevy c10. Tail lights
Shaner87
Missouri
Shane
How do I change my original taillight / brake / turn signal into three separate led lights??
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
You can cut the brake light wire after the brake light switch befor the turn signal switch then run a wire from the brake light switch to the rear of the truck to the new brake light . the turn signal switch will never get a brake light signal so it will work as the turn signal only .
Shaner87
Missouri
Shane
So I found a orange wire which is hot all the time and a white wire which is only hot while Pedal is down. Which wire should I cut??
Ohiokm
