1978 k10 Suspension lift help
cavalierzz2
Pennsylvania
ricky
So i bought a 1978 k10 with 3/4 ton axles and i went to purchase the 6" lift for it but dont know if i have to buy the 3/4 ton lift kit or the 1/2 ton lift i do not think it should mtter but i need to be for sure before i buy
hirschdalechevy
norcal
rich
k-30
Your are all good to go , same. I have had good luck with skyjacker soft ride , never have had tuff country but lots of guys like them as well , cheap lift kits = crappy ride like rough country.
cavalierzz2
Pennsylvania
ricky
so i can order either one and be fine?
Craig 85
Nashville, TN
454/TH-400/NP205
I put 3/4 ton axles on my 1/2 ton. Make sure you get rear u-bolts for the 3/4 ton. The 14 bolt axle is a larger diameter than the 10 or 12 bolt.
kenny78
Oklahoma
Ken
1973,1980,1982,1985
Blazer(2) k30&k20
The only thing that should be different between 1/2 and 3/4 on a lift kit is rear springs. 1/2 will definitely/should have 52" along the length of the spring. A 3/4 could have 56" with the same measurement.
I am fairly certain that is the only difference
74 Shortbed
A 1/2 ton can have both, I have one of each..
kenny78
Oklahoma
Ken
1973,1980,1982,1985
Blazer(2) k30&k20
I apologize and stand corected
dbarham78
