1978 K10 Pitman Arm
78 Square
Pennsylvania
Justin
Hi guys, new to the forum and to Chevy square body trucks. I just got my truck a couple weeks ago and the teeth in the pitman arm are stripped out. So long story short, I need a pitman arm. Anyone know where I can find one? Junk yards won't sell me just the arm without the whole steering box and I really don't want to spend that unless I absolutely have too. Places like JC Whitney only have the steering arm. Any help would be greatly appreciated. Thanks guys
MadOgre
NA
NA
NA
NA
NA
I know you can get dropped pitman arms but I would stay away from them as the geometry is off when you use them. Even for a lifted truck the raised steering arm works way better.
I would say you are stuck with the price of a steering gear box at the wreckers!
Make sure you torque the pitman arm to the steering gear shaft @ 90 ft lbs and re torque it after you have driven it for a day.
firebane
Calgary, AB
Curtis
This is for a 77 K5 blazer but it shouldn't be much different.
http://www.summitracing.com/int/parts/mog-k6143/overview/year/1977/make/chevrolet/model/k5-blazer
But I do know that their are different pitman arms depending on the year of vehicle so posting a pic would help as well.
MadOgre
NA
NA
NA
NA
NA
78 Square
Pennsylvania
Justin
I'm not home right now or else I would take a picture but it looks very similar to the one In that picture firebane. I didn't even think of looking for one for a blazer. The only ones I could seem to find were the dropped ones for a lifted truck. Guess I just didn't look look for the right thing. I don't see why that wouldn't work. Summit is usually good for returns if for some reason it doesn't work
highdesertrange
kalifornia
mike
k30
if your pitman arms teeth are stripped then your steering box teeth are stripped. or at least damaged. btw some of the pitman arm do not have teeth all the way around, also that pic from summit is not a 4x4 pitman arm. highdesertranger
MadOgre
NA
NA
NA
NA
NA
I already tried to tell them that!
78 Square
Pennsylvania
Justin
Ouch that's a little steep for just the arm. I'd probably be better off buying the whole thing unless I find the right one cheaper. The steering box is fine. I ruined the pitman arm doing something stupid lol. But sometimes you gotta do what you gotta do I guess
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I think I might have one somewhere, I just gotta look for it. Hopefully it didn't get scrapped, its been quite a few years.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
How do you strip out the pitman arm? Those things are bulletproof.
78 Square
Pennsylvania
Justin
Sorry guys haven't had Internet. Well when I bought the truck, it wasn't turning right far enough. It would turn left just fine. But I could barely make a right turn. Someone replaced the pitman arm and the steering wasn't straight would be my guess. I think the truck was wrecked because it's a 78 with an 81 front clip. Anyways, took me forever to get it off. Put it back on and I couldn't get the bolt in. It wasn't perfect. So I figured I'd pull it off another day and reset it. Stupid me, I was showing my dad that it was as close as I was gonna get it by turning the wheel without a bolt in it. Stripped the whole thing. Oh well what are you gonna do. Sh*t happens right?
78 Square
Pennsylvania
Justin
If you still have one, I'd greatly appreciate it if you'd sell it to me
MadOgre
NA
NA
NA
NA
NA
You just needed to adjust the drag link. The adjustable piece between the drag link and the steering arm.
78 Square
Pennsylvania
Justin
Wish I had known this sooner lol. Oh well. Ya live and learn. My steering wheel was completely upside anyways
Garcjay
