063 heads on tbi WHAT SAY YOU ??
roy c
long island
roy
I have a set of 063 vortec heads that I'm considering to put on my 350 tbi rebuild I also have the gm. intake I was wondering if its worth it or shouldn't even bother. also is there any other things I have to do.
thanks to all Roy
Swims350
Logan WV
none
is it gonna be carb or tbi?
vortec heads give more power over any other stocker right off so they are good and worth it, but for tbi might need a chip burnt not sure.
roy c
long island
roy
its a tbi motor
Swims350
Logan WV
none
yes I know it's a tbi motor just wondered if you were going to keep it tbi or make it a vortec head carb motor.
I've seen a lot of uys do the vortec intake tbi setup or even vortec carb intake with a tbi adapter plate and make it work but some have used big block tb's or injectors and what not and some used a chip or all can't remember, but any other plans like bigger cam? egr system?
Driver4r
Nebraska
Trevor
k10,c20
What did 063's come on? Ive only heard of 906/062/and some 305 head.
roy c
long island
roy
I was only going to change the heads and intake was wondering if it was durable keep the rest the same
junkyardog05
Tennessee
Keith
454/ 400 turbo/ NP203
Vortec heads have a different bolt pattern than non vortec heads.
Vortec heads have 4 bolts in each head 2 in front and 2 in the rear 0 in the middle.
Non-Vortec heads have 6 bolts in each head 2 in the front, 2 in the middle and 2 in the rear.
Snips71
