SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
I'm not going to go as far as to call it a tutorial, because I may not make note of every single nut and bolt, so this is a how to. Anyone with a set of hand tools and average mechanical skills should be able to do this no sweat. I'm upgrading this to a 2 beer or 2 whiskey and coke job, but not more than that. It's really not bad the hardest thing is couple tricky bolts and just working with small delicate 40 year stuff. I'm doing this on a 1984 Chevrolet C20 with air conditioning.
First thing is first, the housing under the hood does NOT get removed, you'll be removing the housing under the dash which sounds terrible, but as far as heater cores go these trucks are a breeze. You will want to lay something on your carpet, coolant does not dry well and ethanol glycol coolant especially if it's old tends to be stinky.
It took me 20 minutes to have the box out of the truck and on the work bench in the shop. About 30 minutes to change the core - it should have been less but I had forgotten about some of the tricky linkage and hidden bolts as it has been a long time for me, but I will show you those so it should go more smoothly for you. 15 minutes had the box back in the truck and me pouring coolant back in.
_________________________________________________________________________________
First thing will be to remove the heater hoses from the heater box under the hood. If you need to drive the truck while the core is out simply connect the heater hoses together with a 5/8" to 3/4" connector. Before you remove the heater hoses you can either drain a bit of the coolant or plug the lines with hose plugs or large bolts.
Next empty the contents of the glove box, and remove the 3 or 4 bolts at the hinge. Open the glove box and remove.
Next remove the duct that is just to the left of the glove box and slightly behind the ash tray. 3 1/4" bolts held mine on, it slides out easy. Some folks like to remove the floor distribution box, I don't if you choose not to you just have to be mindful you don't break it off when moving the box in and out.
Working from the outside there are 4 studs with nuts that need to be removed. Do not remove and of the bolts, only the nuts on the studs, the bolt under the hood hold the under hood unit on and we are NOT removing that. When you are looking from under the hood the lower left nut is the only tricky one. A guy could do it with a hand wrench, enough time and enough flexibility but a 18" extension and a wobbly you can get right on it.
Below, Red circles are studs you can see, yellow circles are studs you can't see and represent their approximant location.
Next working from the inside again there are two bolts that must be pulled:
Can't see them in the pic but if you look in that general area you'll see them
Next pull the heater box off the firewall towards you and down. At that point you'll have easy access to the linkage on the top:
Mark and disconnect the linkages circled in red, leave the other two hooked up.
There are three vacuum connections, two kind of on the top and to the back one on the far left. It's pretty hard to get a picture of these as you pull the box, but once you have the linkage unhooked you should be able to lower the box enough to get good hand access and visuals.
From there put your heater box on the work bench. I will work on that in the next post, which I intend to work on right away but I am at the shop so we'll see.
