Wtb!!! Drop Member
Joshua8336
Dirty South AL
Joshua
WTB 2 wheel factory drop member for my 85. don't need the control arms, steering etc, just the drop member. Thanks
To bad you don't live closer, I will have one you can have.
What does it say?
Sent from my SM-T210R using Tapatalk
I myself am not certain what a drop member is. I'm going to assume its the member that goes under the engine and all the A frame suspensions bolt to? :shrug:
Are 1/2 and 3/4 ton drop members the same???
Joshua8336
Dirty South AL
Joshua
i'll ship that bii. i'm that desperate, PM pics please. i'm over eager to get my c10 rolling again. needs all hardware too
OK, so wft is a drop member? I might have one too. :shrug:
Joshua8336
Dirty South AL
Joshua
it's the crossmember that goes under the engine that the front suspension bolts to. mine was rusted so I scrapped it. my mistake, didn't figure they'd be this hard to come across
I have a feeling 2wd 3/4 ton and 1/2 would be the same. It's the A Arms and shafts that are different, but I just scrapped 1. However, if this damn weather would warm up I do have another C20 frame that's going to be scrap. Just not real sure how fast that will transpire. I'd imagine between Shawn or myself, we should be able to get you hooked up. I have a feeling it's heavy enough it'll need to be strapped to a pallet and freighted. Not sure where he is in TX, and I'm in OKC so it's not a long terrible distance either way, as in like going all the way across the country.
I'll try to get some pics for you today. It's still in the truck, I'll have to pull it out. You said you need all the nuts and bolts also. I have no idea what it will cost to ship, your probably looking at a few hundred dollars. I'm guessing, it being striped down, it probably weights 150lbs.
Joshua8336
Dirty South AL
Joshua
mine wasn't too heavy after all of the control arms and steering was taken off of it, maybe 60 lbs. maybe my refund will post tomorrow and we can get things moving along.
yeah. i'm only a few states over. maybe it won't be too bad. but at this point idc I need to get one on it and get it rolling around.
I didn't think it would be that light. Here's some pics:
Joshua8336
Dirty South AL
Joshua
lemme get that off your hands bud.
bdiamond
Wichita Falls, Texas
blazer
I could use the small crossmember at the very front if you're wanting to part the rest.
gmount0985
