Tubular control arms
Jarhead79
Mt Vernon il
Michael
Anyone running with the lowered tubular control arms and upper tubular arms? I'm thinking of going this route instead of using the stock stuff. Any pros and cons that you can give me will be appreciated!
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
In for info.
74 Shortbed
I'm interested in this, been thinking of going this route on mine too..
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Not running tubed arms yet....
pros...camber adjustability beyond stock
much stronger than stamped oem
offered in shorter length in order to tuck front wheels AND turn without body interference ( of course if running 14" wide front wheels, mods have to be made).
Lighter than oem
easier and cleaner to install airbags with tube arms
I plan on building up my current square to road course and in doing so, tubed arms are the only sensible way to go
cons....price if custom built.
Airbagit.com has reasonable prices for arms, with balljoints included.
74 Shortbed
Well, I definitely want to go with tube arms(no air bags though)but my main concern is quality lot of offshore junk out there, also want them designed for lowered trucks, I have seen some that are supposed to be for lowered trucks but still takes a ton of shims and the retaining nuts don't have full thread engagement with proper camber, I plan to do a lot of traveling with the truck when it's done and I want it to be safe..
IvanBlock
Dallas
Sierra Classic
In for this also.
Sent from a Motorola car phone
northeimcustom
WISCONSIN
northeimcustom
lots of people go with Porterbuilt control arm set up when using airbags and getting super slammed. but they are $$$
michigan metal works, ride tech, CPP, DJM are among others that makes some good products as well
Jrgunn5150
Ionia Mi
J.R.
6.slow
I've never heard of Michigan Metal Works, I'll have to look into them, thanks!
Jarhead79
Mt Vernon il
Michael
Michigan metal on facebook! His flat stock uppers and lowers seen really reasonable for 73up c10s
74 Shortbed
Maybe I missed it but seems like they only have lowers for bags, none for springs?????..
IvanBlock
Dallas
Sierra Classic
See the notes at the bottom, specify for spring perches upon ordering. No extra charge
74 Shortbed
Yep, I missed it thanks for the heads up..:cheers:
morrow07
San Mateo, Ca
Ryan
Cheyenne - V2500
I have CPP upper and lowers. Definitely more camber, but not weight. They actually weigh more then the stamped OEM arms, but are built very well. No doubt they are much stronger, and look great on top of it.
Sent from my SM-G900V using Tapatalk
74 Shortbed
Thanks for the info, been looking at those they do look stout, only thing I wondered about is the uppers with the ball joints on the bottom that puts all the stress on the bolts, wonder if anybody has ever had issues with that????..
Dennis Blom
