Too much end play?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
So while working on my rear breaks i pulled the drum and noticed the in and out play. Is this too much play? Should i be worried? Sorry that the video is so short but i got a phone with a full memory.
shanegtr
Perth, Australia
Shane
R2500 Suburban
shouldn't have any end play (well at least none that visible to the human eye)
A little bit is common, but that's a bit excessive.
highdesertrange
kalifornia
mike
k30
x2 that's a lot of play. get it figured out, it's axle, the spider gear, or the c-clip. or it could be a combination of all three. highdesertranger
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I had to shave off a tiny bit from the axle to swap it in to the 10 bolt. Maybe i took too much?
Could be. If you took off too much, the shaft might slide in far enough to lose the c-clip.
Jleopard77
