Replacing ignition key switch ?
MikeB.84
My ignition switch will not always lock. Most of the time you don't even have to have the key in the ignition to start the truck. Do any of you guys know how hard it is to replace? Also what is the best key switch to go with? Thanks
1. Remove steering wheel
2. Remove turn signal switch
3. Place ignition switch in ``Run'' position, then remove lock cylinder retaining screw and lock cylinder.
4. To install, rotate lock cylinder to stop, while holding housing as shown, Fig. 6. Align cylinder key with keyway in housing, then push lock cylinder assembly into housing until fully seated.
5.Install lock cylinder retaining screw. Torque screw to 40 lb in for standard columns, or 22 lb in for adjustable columns.
6.Install buzzer switch, turn signal switch and steering wheel.
MikeB.84
Thanks. I'll give it a go
friscobob
Sutherlin Oregon
Bob
C 10
Is it possible to disable the column lock and keep the ignition lock?
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Yes, leave the steel locking plate out and the wheel won't lock. Best advice I can offer is finding the compressor tool for the lock ring, it's almost impossible to put back together without it.
72chevy2door
Florida
Jeff
1500 Sierra Classic suburban
You have to have the locking plate. It holds down a tension spring for the bearings at the top of the coloumn. He can chop off all the little numbs that are on it or he can remove or cut off the silver rod that comes out the coloumn that engages the lock plate. Just has to make sure it's poking out all the way before he cuts it so it doesn't lock when he turns the key off.
highdesertrange
kalifornia
mike
k30
72 chevy is right on about the locking plate. highdesertranger
Danger Dave
