rear lights
Brandon_l1000
Tennessee
Brandon
350/sm465/np205
hey guys i have to re wire my back lights brake lights, back up lights, signal lights the whole deal. my question is what gauge wire should i go with. i was thinking either 16 or 14?
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
16 is probably factory and fine but thicker wire theoretically will carry less resistance and pprobably has thicker insulation to avoid rub-through later on down the road... Just make sure you connections are shrinktubed so you dont get a bad connection later due to water
Brandon_l1000
Tennessee
Brandon
350/sm465/np205
ok and i was going to solder all the wires then shrink wrap them. would that be ok? i figured it would be better than butt connectors.
thebrad
Hillsboro OR
Brad
I just did mine on my stepside. If you run into trouble send me a message and i might be able to help.
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
perfect! thats what i would do!
Dennis Blom
