Rear Driveshaft question.
chevysilverado1987
Michigan
Ryan
I have a 1980 3/4 rolling chassis with the 44 front and 14 bff in the rear. I don't have a rear driveshaft for it. I am putting my 350/350 turbo/ and t-case in the rolling chassis. will a long box 1/2 driveshaft work? Or will I have to find a custom one? Thanks.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
I just did something like this and and they are two diff sized splines from 1/2 to 3/4, i ended up with the 3/4 yolke but the 3/4 driveshaft was so bent up i didn't want to use it. So i stuck with the 1/2 shaft and yolk and just ran a combo joint at the rear. Works just fine.
chevysilverado1987
Michigan
Ryan
Have a part number for it and where you got it from?
carter34
