Rear Barn Door Power Lock Issue
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
My burb has the rear barn doors and power locks. The locks work on the 4 passenger doors, but has never worked on the rear barn door in the several years I have owned the truck. I finally broke down and tried to fix it this week. I started with replacing the lock actuator inside the door with a new one. I figured that would do the trick, but no luck.
Next I cleaned the brass contacts on the frame of the cab and the 4-plunger switch on the jamb of the door. I checked power to the contacts on the cab, and power is good. But the actuator still doesn't work. My next step is to try to replace the 4-plunger switch on the jamb of the door (see the photos below of the switch). 2 of the plungers are very stiff. Anyone know where I can get a new one of these switches? I have had no luck tracking them down at standard parts stores. GM said they are discontinued. LMC doesn't carry them. Anybody have a good spare laying around?!
I'm trying to make this motorhome run correctly, and there's a four plunger jamb switch very similar to that one on the main door. You might try the motorhome world for something like that. Mine's an '89 Holiday Rambler.
yevgenievich
Place
Name
Year
Model
Size
I have to look, but I think I might have the switch from a 90 suburban that you are looking for. It is used, which is the main downside. You might be able to take the one you have apart, clean it and put it back together
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Just out of curiosity, is it possible to supply 12v to the circuit in the door after the plunger switch to verify that's the problem?
yevgenievich
Place
Name
Year
Model
Size
Use a 12v. Battery and apply directrly to one if the terminals. Ground is from door it self i believe(connect battery negative to the door metal)
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
Just saw all these messages this morning. Thanks for all the replies!
Update: I did some more testing last night and found that I was getting power to the plug connector at the door lock actuator, but the brand new actuator still was not working. This means the plunger contacts on the door jamb are working fine. WARNING: The following is my best attempt at describing the issue, but does not contain the correct technical lingo... The metal pieces inside the plug connector (on the wiring harness) were actually separated too far apart to touch the metal contacts on the actuator. I squeezed the metal pieces inside the plug together, and VOILA! The actuator works now. BUT, the actuator doesn't have the strength to operate the lock linkage inside the door. I am thinking I need to lube up the linkage components. Will keep you all up to date as I can. I have several projects going on right now on the dirtyburb.
chubhub6969
