Question concerning LED bulb upgrade?
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
I recently ordered and received all LED bulbs necessary to change all my exterior lights and markers to LED except for headlights. My question is: is this as simple as removing the incandescent bulbs and installing the LED bulbs or is there something that needs to be addressed in order for them to operate correctly? I know this has been discussed before but my search function has never worked, always says: no results found. TIA:cheers:
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I switched my headlights, reverse lights and license plate lights to led and it was just plug and play. Nothing extra needed for me on my 2015 camaro.
I really like them too.
:cheers:
Ps. If their hard to push in? Just flip them 180 and they should slide right in.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Yes messing with any turn signal light you will need an led flasher, I would get one for both the signals and hazards, if not your lights will hyperflash with signals or hazards on.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
:cheers:
Just be aware of polarity. Most LEDs will not function if you get the +/- backwards. Probably not an issue with bulbs that are inherently polarized like brake lights, but could be with peanut bulbs in marker lamps or as someone here found out, dome lights.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Wait... what are we talking about?
When I was replaced the rev lights it was kinda hard to push them in. So like the video said just flip them 180 and they slid right in. Why? Idk but, it worked for me.
Just a tip that helped me :cheers:
Paladin
"Teufelshunde"
Thanks for the responses guys! Since I had to order the flashers I decided to go ahead and order the headlights too so now will wait till everything gets here so I can do it all at once. Decided to order a few spare sockets also in case I run in to some which might need replacing! Should be a all day project once everything arrives, that's calculating in all the beer breaks too! LOL :cheers:
Paladin
"Teufelshunde"
John-Ryan
John-Ryan
V20
Subbed
clendon1
Polk City FL
Butch
c10 stepside
468 BB
What are the brightest LED bulbs for replacing the stock 1157 bulb ?
probably 3157 in an LED
