Push button starting
mr.hotrod
Indiana
Evan
Hello everybody, I decided that my 1986 squarebody needed a switch and push button starter. I'm not particularly worried about theft because my primary transportation is my motorcycle in the summer, and my Blazer is my primary transportation in the winter, otherwise the truck gets driven to mud bogs, or put in the barn. To end my rant of my life story, my problem is that wiring diagrams are greek to me, so I was wondering if anybody could help me through the process of hooking all this up. Thanks, Evan
Hoodbj
Billy
R10
If your switch is still functioning you can add a push button to engage the starter. Run a wire from the positive terminal of the battery, I would then install an inline fuse just in case something rubs it'll pop the fuse and not burn down truck. From the inline fuse continue with the wire to the push button. On the other post of the push button you can either tie into the existing wiring that goes to the solenoid (not sure the color, I think I've read purple but don't quote me on that) or simply run a new wire from the push button to the small terminal on your solenoid. If your ignition is also bad hopefully someone else can jump in on this. But as far as a push button that should get your starter spinning assuming the large cable from the battery is still hooked to the large post on the starter.
alwaysbroken
