Manual Valve bodies..
bobkyle2
Illinois
Kyle
K5 Blazer
I'm in the process of buying 2 new manual valve bodys for our race trucks, We've never ran them. Don't know much about them...
Both th350 trans...
I've been looking at the automatic/manual valve bodies, Will i be able to delete the vac mod and kick down cable with the auto/manual ones??
I know you can with the full manual, but with a full manual i'm pretty sure you loose your engine braking.
Both trucks are full mud race, no street time.
Anyone ever used a auto/manual valve body?
:popcorn:
Sent from my iPod touch 4th Gen using Tapatalk
nvrenuf
Mobile, Al.
I've never seen automatic/manual valve bodies, only shift kits, but it would seem that if auto shifting is an option then the vac mod and kick down would have to be retained.
As for full manual valve body's, there are some out there with engine braking on the lower gears.
bobkyle2
Illinois
Kyle
K5 Blazer
From what i gather, is it will shift normally if in drive... But if you shift manually it will shift...I don't want anything to do with the auto part, will be shifting manually 100% of the time.
Hope someone has used one before.
nvrenuf
Mobile, Al.
If you don't intend to let it auto shift then why bother with the combo valve body? Shop around for a full manual, reverse pattern valve body WITH engine braking.
bobkyle2
Illinois
Kyle
K5 Blazer
They are much cheaper.... If i can get buy without spending the extra cash, I'm going to. As i'm buying two of them. No sense in spending the extra cash if i can get cheaper and still do everything i ask of it.
