Lock up converter - not feeling the love
gwcrim
Ohio
George
The ride:
1980 C10, mild roller 400, 200-4R, 2-2200 converter, 3.73 gears, 27.5" tires. Nothing fancy or unusual.
I thought when I had the trans built that it would be nice for fuel economy to use a lock up. It's wired through the brake switch, then to a toggle switch, then to the vacuum switch. When I drive the truck around w/out the converter on, it feels decent enough. When I let the converter lock up, it acts in a way I don't like. From very low speed, it shifts into drive pretty quickly, then the converter locks up, then it downshifts. From a 35-45 mph cruising speed, if i accelerate up a small hill, the converter locks up and the RPMs fall badly.
Is this what I should expect from this set up?
Any tuning tips or other words of wisdom?
-Crim
4WDKC
Southern Florida
Kacy
I don't have a 200-4r or a vacuum switch but my 700r4 does not act like this.
Sent from my SAMSUNG-SM-N900A using Tapatalk
74 Shortbed
I ran my 700r straight off a toggle switch, lock/unlock whenever I wanted, just had to remember to unlock before coming to a stop, lol..
yevgenievich
Place
Name
Year
Model
Size
It might need an adjustable vacuum switch and also wire it to come on only in 4th gear.
gwcrim
Ohio
George
I'll explore the idea of an adjustable switch. How can I have it only engage in overdrive?
robracing85
