Introduction and rear question
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I'm almost certain that 2000 rearend is quite a bit wider than what you have. Could probably still use it, but you may have to change your wheel plans. Or you could always have it cut down to whatever length you want. Spring perches likely aren't in the right spot either. I went down this research road with my '85 and ultimately just rebuilt my original 10-bolt and upgraded to 30-spline stuff with a Yukon Duragrip and 3.90 gears
Zach, which axles did you use? Love Yukon, have it an a few different applications and all are still going strong. I also have had excellent results with Strange engineering, and a great company to work with.
Sad Sack
Nebraska
Goober
C15
:welcome:
I used Quick Performance's axles. I'll probably go with either Strange or Moser for the next set just for peace of mind, not totally sure how strong the QP's are. They've been fine at 425hp on the street but who knows once we start racing this thing and later on when I do a bigger motor
Craig Nedrow
Washington State
Craig
K10, K20, C20
You got the sickness same as me Zach> pretty soon you will be making midnight forays scrabbling around for a better set of may pops
duncan_schawalder
