I have no idea.....
CRM
Pasco, Washington
Casey
K2500
350 CI
While removing the screws that hold the front bed panel, I found a 3 prong electrical connector on the driver side between the cab and the bed. It comes off a larger wiring harness under the truck and is held by a screw thru what looks like a ground wire. It's located right below the top of the bed. I think it has something to do with the slide in camper that was on the truck when i bought it but that's just a guess. Any ideas?
74 Shortbed
Yep, I had the same thing on my dually it was to power the camper while traveling.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Different plug, but same location and function. Provides power for a slide in camper.
Dennis Blom
