Help on swapping out 4.3
Grizzly85
Minnesota
Kyle
Any advise on swapping out a 4.3 to 5.7
marks86
Latham, NY
Mark
12v Cummins
probably one of the easier swaps to do, as long as you understand a 4.3 is the exact same motor as the 5.7 just with two less cylinders, I know right off the bat your gonna need a new fan shroud
MadOgre
NA
NA
NA
NA
NA
You will need to get a cross member from a V8 truck or build one. I think you can buy after market ones too.
I would ditch the ESC distributor if you have it.
Apparently the stock 4 barrel intake and carb has some good value if sold.
Aside from the cross member I think its pretty straight forward except like Mark said you will need the V8 fan shroud and possibly a bigger rad too.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
have to change lower motor mounts and stands on frame. 4.3 sets back further
MadOgre
NA
NA
NA
NA
NA
You have to move the cross member forward as the motor mounts are attached to the cross member in K trucks.
but you cant reuse the old cross member because you would end up with slotted bolt holes due to the frame being narrower towards the front.
towjoe
Lafayette,IN
joe
K30's or V3500's
I didn't realize it was a k series not a c series. I swaped the 4.3 out in a 86 c20 4 speed once and had heck of a time because I didn't realize all the lower mounts were different. 3rd try setting it it fit like a glove tho
Qwk
Cincy
5.7/T56
What mounts did you end up using?
towjoe
Lafayette,IN
joe
K30's or V3500's
I used everything off the donor truck and same holes as it. Easy swaps when have both trucks side by side
Qwk
Cincy
5.7/T56
Crap! I only have my one truck.:)
MadOgre
NA
NA
NA
NA
NA
well I guess you better go get another one lol.
Heck I would have my own square wrecking yard if my wife would let me!:lazer:
marks86
Latham, NY
Mark
12v Cummins
from my experience with doing a motor swap having a doner truck parked right next to the truck getting the motor is literally the best thing you can do
cmcqueen
