Cruise control
Boltrunner
Odin mn
Shane
V20
Ive searched gmt400 cruise control and only saw one mention of it being put in a square. Unless im not searching the right words. But how difficult is it to do? The mention i did see seemed to infer it works. My truck is not a factory cc. How would i go about putting it in. I have a 95 suburban that i am pulling everything off of. It all works. Have used it maby times. I have a sm465. Would i need the turn signals lever off the suburban as well? And what all has to come off to be put on my sb
4WDKC
Southern Florida
Kacy
If the 95 has a system that works off of vacuum you can swap it to yours, if it uses the VSS from the 95 you would have to swap the efi. Either way you would need the signal switch and lever, you would also have to run a wire from the signal switch connector under the dash to under the hood. Along with getting the brake light switch.
87Chevy520AZ
