Corvette Cruise Control
Kane Rosengren
Illinois
Kane
I have a 1979 c20 Silverado on a 78 k10 frame. I believe that there’s a 77-79 corvette cruise module mounted on the fender. Would this ever work? I have the A port hooked up to engine vacuum, the b port as a vent, and the c port connected to the brake pedal. There is a 2 wires connecting connector on a slider connected to the gas pedal. And the 2 wires connected to the module appear to be connected right. Just seeing if anyone is familiar enough with both systems.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Maybe post up some photos of the cruise control setup so we can see what you're seeing
ali_c20
Austria
Alexander
C20, K5
I think the same cruise control system was used in many GM vehicles with gas engines.
The transducer was used from the early 70ies up to 1980.
Turn signal lever with the cruise knob is the same in Camaros, Impalas, Pontiacs, El Caminos,...
I don't know if the transducers had different calibrations.
That's what I remember when I tried to fix the cruise control on my K5.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
An an amazing amount of info here - the link opens right up to it.
I open it with Drive on my Android phone - built in program.
And, if you look at the 2nd link (1st is dead ) you will see where the ccredit goes for the link from the 1st post of here.
Nborden88
