CONNECTING ROSTRA CRUISE CONTROL CABLE TO EDELBROCK CARB
80sHottrodder
Greg
350/th350c
Anyone have any pictures of how the cable from a rostra aftermarket cruise kit is ran to the throttle linkage? Carb is a 1406 edelbrock.
5akman
CA
Lance
I'll be curious to find this out also.....
80sHottrodder
Greg
350/th350c
I installed it yesterday. Ill get some pics of how I hooked it up. Seems to work fine so far.
80sHottrodder
Greg
350/th350c
I bent and cut the included cruise cable bracket and drilled a hole in the existing throttle/trans bracket and ran a small bolt through it. Then i pulled the cruise cable all the way out to determine how much bead chain i would need to connect it to the carburetor. The cruise stud is actually from a quadrajet, ran through the biggest hole on top.
twzorek
