Classic industries stereo problems
X piped
Alberta
Shane
Sierra Classic 1500
Small block
I installed a classic industries stereo in my 85. It worked great for 1 summer. Now the stereo shuts down after a few seconds when I turn it on. It turns on every time. Any thoughts on what could be the problem? It would do the same thing when I first installed it with 4 speakers bridged to one channel. I then installed a 2 channel 200w amp to run my 6x9s. Now I just have my factor front speakers and factory rear speakers on the 4 stereo channels. It worked find like this for 1 summer.
350runner
tx
Ceasar
4 speakers bridged to one channel is no good. What did they ohm out at with all 4? This is likely the cause
MadOgre
NA
NA
NA
NA
NA
This is the retro 2 knob stereo ? I have one too and its a PIS. I don't care im gonna but a single din In mine. I don't care if its era correct or not lol
Plus then I can get blue tooth and usb. I seen a guy that had the blue tooth microphone attached to the top of his steering column right behind the steering wheel. Looked like it would work well.
X piped
Alberta
Shane
Sierra Classic 1500
Small block
I have 1 speaker ONLY on each channel of this stereo.
I have 2 additional 6x9s on an amp. I think you accidentally misunerstood me. Any ideas?
350runner
tx
Ceasar
Ok, I was just going off what you said. Usually the transducers go out ands cause this issue it will cause a stereo or amp to go into protection mode or just stop working.
X piped
Alberta
Shane
Sierra Classic 1500
Small block
Does that mean the stereo has to be replaced?. Is there a chance of something easy like a bad ground?
350runner
tx
Ceasar
Yea sure try fixing the ground. Any stereo can be rebuilt.
boarder421
