Cab lights
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
So I replaced my cab lights and now there not working. But all other running lights work is there a fuse just for cab roof lights
Big Chip
Michigan
Kevin
C35
It’s probably those funky ground clips. I ended up putting terminal ends and running the mounting screw for the lense through it. I know another guy who ran a ground from the lights back down the pillar to the buss to get his working.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
I mounted the end ground to the screw hole. Problem I think I have it I had the lights on during install and I cut both wires at same time on accident they turned off wired it up and never turned back on. I need a dam power probe lol. Each light has a red and a black wire put in series. Can u mess that up does it matter which one you connect to.
Big Chip
Michigan
Kevin
C35
That wire is wired into the headlight switch so I don’t think there’s a separate fuse but it’s been a while since I messed with it and I may be remembering incorrectly. I’d say it could only be a power issue if it’s all grounded correctly.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Right I'll have to pull them all off at same time and see if theres power any where in the line I imagine if the first lights bad none would work
acesolis
