Bumper & Frame Issue
MadOgre
NA
NA
NA
NA
NA
So basically you gave up and did a frame replacement. If that is what this is going to take then I am just going to part this thing out. Trying to find a frame where I will be next to impossible.
I still have it but I am not going to do a frame off build with a bent frame!
But in that thread there is some info on the frame measurements
firebane
Calgary, AB
Curtis
Yeah I saw the frame measurements and oddly from the center of the crossmember to the inside of the frame rails the left side is 14" but the other side is just over a hair which I'm not concerned about.
If I measure from the bottom of the rad support out to the end of the frame horns there is almost 1" difference.
If someone would be able to provide that measurement that would be awesome.
MadOgre
NA
NA
NA
NA
NA
So your saying that one frame horn is 1" shorter then the other? How is the rest of the body sitting on the frame? If you measure the rear frame ends are they symmetrical?
If the frame is fine at the back but 1" short at the front then one side needs to be crumpled or stretched to get that extra 1"
So on a flat concrete pad you can use a plumb bob and mark the locations of the frame points onto the concrete. Then also measure the height from the concrete to the frame, both top and bottom of rails.
Also you need to use large jack stands under the frame not the suspension. So set your jack stands to the same height and locate them onto the same spot of the frame from side to side and at the same height.
firebane
Calgary, AB
Curtis
I don't have the luxury of flat spots and jackstands and plumb bob unfortunately.
But I just went out and measure from rear cross member to end of the frame and on the left side I get 11 1/2 and on the right I get 11 3/4
So even at the back end I am out 1/4 of an inch.
MadOgre
NA
NA
NA
NA
NA
Are you measuring from the edge of the metal or from a location hole in the frame?
Its completely reasonable that the edges do not measure up right. But if you use the locating holes in the frame you will know for sure. Is the rear bumper bent?
The only way to find out what's going on is to do the flat concrete thing or take it to an experienced frame straightening shop. :sorry:
MadOgre
NA
NA
NA
NA
NA
Or just live with it.
Have you thought about buying another truck that has a good frame and combining all your good parts from both to make 1 good truck?
firebane
Calgary, AB
Curtis
I have put out feelers for shops to put it on a jig but I have yet to hear anything :(
I measure from back edge of cross member to end of the frame edge as I have no bumper right now on the back.
Tomorrow I will measure center to center of the tires in both sides and see if there is a difference. If there isn't I might just section the short frame horn to fix it.
I simply do not have the funds to buy another truck.
Skweegle89
Oklahoma
Just asking for my own curiosity. Did you drop all the weight on those springs before you tightened the bolts?
MadOgre
NA
NA
NA
NA
NA
Well I would just put some large washers behind the bumper to make it straight then! And just drive it:)
You really have to measure in an X and measure from a flat surface. Then compare to see where you are. Measuring from a cross member to the edge doesn't really tell you anything.
FYI when measuring in an X say one side says 100" and the other says 100" and 1/2" then you would be 1/4" pushed sideways toward the side of the longer measurement. To get it square both sides should read 100 1/4"
firebane
Calgary, AB
Curtis
I was given this advice and it was great advice and something I can very easily do!
To check the "square" of the frame. Find 4 holes, two in the front and two in the back in the frame. Make sure they are mates. Same on drivers side and passenger side. Take some fishing line and sinkers. drop lines from those 4 holes. Making sure that the line leaves the holes at the same point side to side. Then measure Right front to left back, and left front to right back. That will tell you if the frame is square.
MadOgre
NA
NA
NA
NA
NA
That will work but you still should have the frame level and not bound up by the suspension or weight of the vehicle pushing and binding the suspension.
I guess my question to you would be: If it turns out, its not square, what are you going to do about it?
firebane
Calgary, AB
Curtis
Yesir that is definitely one thing I know to do.
firebane
Calgary, AB
Curtis
Well obviously nothing lol. I am just curious why none of this **** lines up. And I also wonder if this has to do with the weird steering feedback I get when turning tight.
FenderBanger
