brake light Switch
pj337
lake charles
earl
I just bought a 83 c10 and I have no brake lights when pressing the brakes. brake lights glow with headlights on. turns signals, reverse lights work. I changed the brake light switch didn't fix the problem. I did notice that I'm missing a connection on the brake light switch could this be the problem. If so what harness do I need to buy. Thanks in advance.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I would fix all the scotch locks as a start. Then look around for a connector somewhere in there
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Yep, your missing a plug. Look for a connector with a orange wire, and a white wire. The orange should have power all the time, the white wire will have power with the pedal pressed. Once you find it, if things still don’t work, check for power at the white wire if the turn signal switch. If good, check for power at the yellow and dark green wires at the turn signal switch. If you have power at the turn signal switch, but nothing on the yellow or green (with the brake pedal pressed) you need a turn signal switch. Before tearing into the column, press and pull the hazard switch button a couple times. I have had funky turn signal/brake light issues solved that way. And I agree, get rid of the scotchlock connectors!! I hate those things. Good luck
pj337
lake charles
earl
I found orange and white wire but no connectors. How can I make it work I can't find a store that sells the connectors
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
You could always use crimp on insulated spade terminals, or find a donor connector from a junk car/truck. Pretty sure GM used the same connector from at least the mid 60s to mid to late 80s. Before you get carried away, make sure you have the right wires. Dome lamps also use orange/wire wires. Disconnect the battery, use a self powered test light or meter. Unplug the turn signal switch, check for continuity between the white wire at the turn signal switch harness connector, and your suspected white wire. If you have continuity, plug everything back in, reconnect the battery, and use a fused jumper wire to connect the orange to white wires. If you have brake lights, all is good in the world. Reassemble your truck, put away the tools, go in the house, have a beer, and prop your feet up in a badass fashion.
pj337
lake charles
earl
Thanks for all the help, I fixed the lights.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
skyra16
glendale az
skylar
k20
Where can I find the wires coming from?
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
I Would look for bad ground at brake, turn singals too.
FenderBanger
