4L60E/700R4 Linkage Question
Shack
North Carolina
Mathew
For those who have done the swap, did you use the 700R4 linkage with the 4L60 Module like in the picture below or is there something different I need to do? Thanks in advance.
74 Shortbed
I hooked mine up just like the 350, just didn't have manual low on the column.
Shack
North Carolina
Mathew
I thought they were all the same?
This is what I have, but this came up as TH350 linkage.
Shack
North Carolina
Mathew
That's kind of what I was getting at. I put that linkage on the outside of the module. I vaguely remember discussing this with my transmission builder which may be why there was a longer stud on there, to go through the 4L60E module and allow the shift linkage to work as well.
74 Shortbed
I had a 700R in mine, I would think the 4L60E is the same???.
Shack
North Carolina
Mathew
It is, just a computer controlled version
74 Shortbed
Right, so you shouldn't have any problems.
Shack
North Carolina
Mathew
I was just curious how folks did the linkage is all. Thanks for the help.
tman894
