1984 K20 Camper Special
Dano500
Houston, TX
I’ve done a lot of work on it, but it’s no where near done. I’ve driven it from Houston to P-ville and from here to Dallas and back hauling items each time. You can find most of the work I have done through my posts here.
New Tank, sending unit, edelbrock 1406.
New plugs, wires, coil, master cylinder.
New A/C system.
New trans filter w/ flush & gasket.
New 4” springs w/ bushings up front.
New shocks, sway bar bushings, steer box
New pitman arm for lifted trucks, steering stabilizer.
New led headlights & parking lights. Grille.
New sound deadening, carpet, dash pad.
New 10” touch screen, amp, highs/ mids.
New 8” powered subwoofer.
New door window felt.
New vent window rubber & locks.
New 17” wheels.
New 285/70/17 load E tires.
No bodywork has been done. Most of rust was surface when I got it, but the cab has bad cab corners, rockers, passenger floorboard and some firewall rust. 350 w/ TH400. 4.10s
$10k is absolute least I will take.
Truck is located in Plainview, TX.
Here is link to pics on fb ad.
Johns C10 Hubcap
