help with a 1977 chevy 3500 crew cab long box
ol77chev
killam alberta
jackson
I just bought a 1977 Chevy 3500 crew cab long box with a 454 2wd duel tanks ac 3+3 and I was just wounding if first is it a rare truck and is it there any common issues I should watch out for and any tips or tricks with these trucks
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Your biggest issues are gonna be parking it, turning it around, tight spaces, and since it's a big block, feeding it.....pull through parking spaces will be your best buds when you gotta go somewhere.
Family had several square body Burbs which are almost as big, and I currently have an OBS Crew Cab longbed that we DD in Houston, Texas as well as use to haul stuff.
The square 3+3 was not super common, because they were "work trucks" or tow pigs when new. You bought one if you needed to move several people often, plus have a truck bed, otherwise people bought a Burb. Even my '97 is one of only around 15,000 built that year, as opposed to a couple hundred thousand Burbs.
The interior is pretty much like a square Burb, but I don't believe the rear seat folds up like the Burbs do.
Got any pictures? Here is my truck, doing truck stuff.
ol77chev
killam alberta
jackson
il get some pics here shortly and yeah ik its going to be a beast to park i got an old bus and its a pain to park but i appreciate the help if you know any common problems i should look for or keep aware because i believe the engine is seized and the back drums are seized
meizy
