Who sells the best replacement gas tank
I want to make sure i understand you guys.if i buy a tank with the huge seams,all i need to do is grab a bfh and go to pound town?correct?
thats what i did, I dont remember if i needed to do both sides but it may have just been the side that the strap is in contact on the opposite side of the bracket maybe
dusterdude
US
mark
gmc c15
Thanks ag,thats an idea
dusterdude
US
mark
gmc c15
I ordered the amd tank yesterday,probably will not install l it until next saturday,will update at that time.thanks for sll the suggestions.
dusterdude
US
mark
gmc c15
Ok guys,i installed the amd tank just now,nice tank and it fit very well.one question,can i tighten the front strap nut with the tank installed?if so,what is the trick?thanks
You’d need to access it
dusterdude
US
mark
gmc c15
Ag,i understand that.access is very limited because the converter is in the way.im wondering if there is a trick to get to it.
Converter? What do you mean?
i now realize you meant catalytic converter, I gotcha now. I dont have that consideration so im not sure personally. Might have to loosen the brackets back off and tighten it before putting back on the rail
if your cat is original, might be worth removing it to make sure its not plugged up , assuming it has flanges or easy straight-shots before and after you could cut and clamp to reinstall or bolt in/out, etc.
Just a consideration
dusterdude
US
mark
gmc c15
That may be a good idea
cmcqueen
